Need some distributor help guys!
myidea7
I had the inevitable timing guard break causing the chain to wear into my cover on my 91 hardbody. I got another cover, but I think it was from a 95 hardbody and the distributor bolt holes are different so I am assuming the dizzy is also? Can I get the 95 dizzy and make it work, will it hook right up, etc.? Thanks
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
nope, about the only thing you can do is have somebody drill the whole bigger. We really need a sticky about this stuff. peace.
myidea7
nismopu wrote:nope, about the only thing you can do is have somebody drill the whole bigger. We really need a sticky about this stuff. peace.
OK, Thanks thats all I needed to know. Guess I'll be drilling and tapping a some new holes then. Thanks again.
nismopu
1997 Nissan Maxima
yeah, in the mean time for future refference mid 95 nissan pickups were a hybrid obd1/obd2. A friend of mine has a super clean 95 that has side feed injectors, early dizzy, later coil, and no obd2 port. really weird truck. The true obd2's have a different dizzy as you found out, head ports are different to accomodate side feed injectors, and harnesses/ecus are different. 6/95-97 models years
