JDMSileighty423 wrote:why not just put a silvia front clip on a hard body? Save a lot of hassle
correct me if I'm wrong but hardbody: longitudinally mounted drivetrain, pulsar GTIR: laterally mounted drivetrain.JDMSileighty423 wrote:why not just put a silvia front clip on a hard body? Save a lot of hassle you could even go all wheel drive then get a damn Pulsar GTIR setup slammed under there.
The leaky injector leaked down in to myoil where it thinne dit out.So I spun a rod bearing.top_secret wrote:did I read that correctly, you are swapping motors because of a leaky injector? wouldn't it be easier just to fix the injectors?
