ayjay »
https://forums.nicoclub.com/ayjay-u5495.html
Sat Jun 07, 2003 9:53 pm
SIMMSLED YOU A DOPE MODERATOR! :ylsuper
ya all you've said, i've taken into consideration... but I'm feeding the Orion a 1000W RMS, in a slot ported box, and it sounds really sloppy, but that's prolly cause it's cheap Tsunami power, and the port is tuned to 50HZ so it bottoms out on a lot of songs, but puts out the most spl for competitions.
So what i'm gonna do is make a street port as well, which is directly swapable with my competition port, and it will be tuned to 30 HZ, which should help out in the SQ department both for punchiness and hittin those low notes.
but this sub is a BEAST, and will never be good for SQ. so what i want to do is hook up a 10" which i can hook up to the rear channels of my 4ch amp, and listen to that setup for the majority of the time while just cruisin... and then when i really wanna blow someone away, i'll have a switch connected to the remote wire on the Tsunami amp to blast my Orion.
i think that by having two different size subs, you get something called "PHASE CANCELLATION"... same deal with a bunch of rattles cause the rattles cancel out some of the bass which results in lower SPL... it's when do sound waves are identical in both frequency and somehting else, and they just cancel each other out...
i'm not bs-ing, i'm just taking an educated guess :P
