Need some brake info for an s13
sorrowfulkiller
Planning on getting an s13 in june of next year after basic and tech school...
I want to upgrade the brakes with some z32 brakes or similar.... but I know nothing about them. I'm also planning on getting a 5 lug conversion so keep that in mind.
So where can I learn about the upgrade? What parts do I need aside from lines and calipers? Where can I get all the parts for a good price?
Cody240
Car: 1990 240sx SE white with KA24DE
check Andy'sautosport.com they have a huge online database of parts for the s13 and some tech info. but mostly they are good on prices.
MisteenoMike
sean@z1
Car: 1993 240sx
http://www.z1motorsports.com/2...1_700We have the whole set up minus the conversion lines if you have the S13 you will need Brakes rotors conversion lines brake master cyl
the rear you need the Drum brake assy plus the 90 model anchor bolt and 2+2 ebrake cables rear calipers and rotors
the same for the s14 except you will use the R33 ebrake cables
sorrowfulkiller
wow guys thanks a lot... that is absolutely perfect.
Exactly what I needed
ashibah83
Car: 93 SUPA BLACK COUPE
Cody240 wrote:check Andy'sautosport.com they have a huge online database of parts for the s13 and some tech info. but mostly they are good on prices.
AAS is JUNK!! the reason they are "Low" on prices is because they sell absolute junk
sorrowfulkiller
I learned this long ago.... hence why half of my parts list for the 240 project will be coming from enjukuracing
sean@z1
Car: 1993 240sx
We are working on a larger 240 site than anyone i am adding new things every day at least 5 new items to 10 new items
ashibah83
sorrowfulkiller wrote:I learned this long ago.... hence why half of my parts list for the 240 project will be coming from enjukuracing
enjuku racing is good people, i have ordered at least $4000 worth of parts from them
sorrowfulkiller
sean@z1 wrote: We are working on a larger 240 site than anyone i am adding new things every day at least 5 new items to 10 new items
I'll be sure to take a look when I get back next spring ^^
