need some brake help
WI_240sx
Car: 1990 Nissan 240sx se fastback
ive been lookin around to see what i can find for 2 piston calipers, but just about everything requires 5 lug conversions. it would be cool but time and money isnt something i have alot of at the moment.. i was wondering if there is any 2 piston calipers (all 4 brakes) that i could find that would just bolt up to the stock s13 bracket with out spending ungodly amounts of money.. i realize that ebrake and brake lines might need a little modifications, but those arent big deals..
if anyone knows of something please help
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
I have the 1996 v8 Q45 front brake (2 piston) setup. They're a direct fit and bolt up with no problems. The only thing is, the dust shield has to be removedor cut. This has to be done to allow the larger Q45 rotor to fit. Ebay has a redrilled or manufactured 4 hole rotor or you can have a machine shop redrill theQ45 rotor. It doesn't cost much, nor work to get them to fit. That's the basic andeasiest way to go.
Steady_One_S13
This should help out. It did for me.http://www.ka24development.com/brake_upgrades.html
WI_240sx
oh.. i know ill have to get new rotors too
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
i think Q45 would be the best bet for ya...
WI_240sx
Steady_One_S13 wrote:I have the 1996 v8 Q45 front brake (2 piston) setup. They're a direct fit and bolt up with no problems. The only thing is, the dust shield has to be removedor cut. This has to be done to allow the larger Q45 rotor to fit. Ebay has a redrilled or manufactured 4 hole rotor or you can have a machine shop redrill theQ45 rotor. It doesn't cost much, nor work to get them to fit. That's the basic andeasiest way to go.
thank you.. this helps me greatly.. cuz i need all 4 rotors and all new pads, so i thought ide get 2 piston calipers while im at it, but i didnt want to replace the wheel hub and bracket or spindle or whatever that things called..
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
q45
/endthread
