WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Feb 20, 2007 12:47 pm
Zane,
Here's what you need to do. Sit down and figure out exactly what you'll want out of your car. By that I mean, what will it be used for? Is it a daily driver? Will it see road course days at the track? Will it be used for drag racing? What are your power goals? What is your make or break point with the budget? How mechanically inclined are you? Will you be able to tune the fuel management yourself?
There alot of factors that go into the choice of turbo kits and fuel management.
For a quick and easy setup, buy the JGS turbo kit, you don't need a SR downpipe, I don't know where that came from. The JGS kit does not come with a FMIC setup, so you can buy one of those from ebay. They are pretty cheap, but work very well. That leaves fuel management. Obviously when you add alot more air, you're going to need to add alot more fuel. The simplest method is to install a 255LPH fuel pump and use a FMU. The FMU is a rising rate fuel pressure regulator. It increases fuel pressure 8 psi or so for every one lb of boost. This is a very easy and proven method. ANYONE WHO SAYS THEY DON'T WORK IS A LIAR AND HAS NO IDEA WHAT THEY ARE TALKING ABOUT. I'm just getting that out there now, you'll be surprised what people will say because they "know someone" or "read it on the internet somewhere". One must becareful of these internet racers.
With the above list, you can safely run 8 psi on 91 or better octane pump gas. Probably cost you close to $3000.
Don't be afraid of asking questions. We're all here to help each other out. I'm the resident Moderator...we keep things pretty loose in here. Don't take it personally if we screw with you, its never serious. We just like to have a good time. You'll make alot of friends here if you want to.
Welcome to Nico and Happy Boosting WD
