AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Sun Dec 04, 2005 6:26 pm
Well, I've FINALLY made a bit of progress on Project Vert.
It's been a panful 4 months,and I've come *this* close to parking it in storage for a year JUST so I don't have to look at it up on jackstands.
Here's where I'm at:
Was having problems with too much fuel, which we narrowed down to bad o-rings. Bought new o-rings. Nissan gave me (what appear to be) the wrong ones, as they're not quite as thick as the ones I removed. So, in the interest of eliminating one problem at a time, I returned to the 270's, cleared all correction from the SAFC-II and moved on.
New problem: With the AEM wideband installed in place of the stock O2 sensor (wired up correctly), car idles great in open-loop (cold) but bogs, hunts and sputters once it switches into closed-loop operation. We switch to the factory O2 and hook it up and it's great.
So I weld in a 2nd O2 bung so I can use the AEM for monitoring and the factory O2 sensor will simply keep thr ECU happy - Problem SEEMS to be solved.
Fire it up, allow it to warm up, and it's running lean. Real lean. Off the meter lean. So, I dial in some fuel correction (about +8% at 800-1400 rpm's) and it seems happy (idling between 14-15:1). Good deal - Seeems safe to install some NEW 370's I have acquired, which will come later - once it's running RIGHT.
Now, on to the problem that has been plaguing this setup since DAY ONE: It stalls on deceleration. BOV is recirculated, and set to "hard". (Settings don't seem to matter, as I've had it set both hard and soft). Simply taking the rpms up to 2000 and letting it drop results in a stall.
Can I dial this OUT with the SAFC somehow? Or is this a mechanical (non-electronic) issue?
Does anyone see any OTHER problems with anything about my setup thus far?
I hate this damn car. I really do.
