Thanks a lot for the reply dude! But if you retard the cam, shouldn't you advance the ignition timing a bit? Technically, it should allow it to have more of a pull top end?SX APPEAL wrote:4 teeth CCW and you're good to go, nothing else is required. No need to adjust your ignition timing. I've been running this setup for over two years now. Its gonna sound different to, higher pitched, more like a honda. But it'll pull better in the upper revs and I like the sound anyway
Just make sure your cams looks like this:
with the front lobes of each cam pointing directly away from each other with cylinder #1 at TDC compression
Alright, that's great to hear. Thanks! So besides the usual stuff, is there anything you could give me a warning on? Stuff to be careful with etc? Or any hidden steps most people never really mention when explaining the cam swap details?SX APPEAL wrote:You have to retard the cam 4 teeth because its an exhaust cam and the lobes aren't in the same orientation as on the intake cam its replacing. So retarding it is just putting the lobes in the right place (almost) Besides, the ignition timing is controlled by the computer, so whatever you do to it, the computer is just going to compensate for it and put it wherever it wants anyway
this. be careful not to over torque the cam cap bolts. removed the upper timing cover and losed the chain guides if you haven't already. a marker will be fine to mark the chain and gear positions (i used white out). make note of the position of the ignition rotor (if you're pulling the timing cover) and be sure it stays in the position when you re-install the distributor.Razi wrote:I'd guess the stock position would be 0.
Then you count as soon as you rotate it 1 tooth.
