brad.keatts »
https://forums.nicoclub.com/brad-keatts-u192702.html
Mon May 14, 2012 4:47 pm
Need some advice/ help! I have a 91-93 tt engine with some problems.
First it started dying at idle, didn't do anything to fix that and then it started idling high, like around the 2500-3000rpm range. Started messing around and making sure that all the loose vacuum lines are blocked off or fixed, still really high. Then I adjusted the idling screw and lowered it down to around 1000-1200, won't seem to go any lower in idle than that. But now it is missing under power. What could be the issue with it? Any ideas would help. I have to drive from VA to CO tomorrow so kinda in a time crunch.
