onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Oct 10, 2008 3:06 pm
If you are going to sell the car in 6 months, do nothing. Currently there is no issue with the car other than psychological - i.e. your mechanic told you there was a transmission code & he cleared it, so now you have in the back of your mind that something is wrong w/ the transmission.
Next time you get a CEL, pull codes yourself - obdii scanners can be rented free of charge from autozone, kragen, pep boys, etc; you can also do the traditional ecu way.
Why do any kind of major swapping if you want to sell the car?
Even if you are keeping the car for the long run, unless you want a 5-speed really bad, there is not reason to swap out an entire transmission (and possibly introducing even more issues) when nothing is knowingly wrong.
As the adage goes, "if it ain't broke..."
