Coty »
https://forums.nicoclub.com/coty-u63981.html
Sun Apr 29, 2007 3:34 pm
I just got my brothers 240sx running. Heres the list 89 nissan 240sx with black top sr20det. Brand new engine harness. 300zx maf sensor.
My history: I am a auto technician and master ase certified. I have a heavily modded dsm (haha) and I am building up my brothers car as of now. I am not a noob so please only constructinve comments.
I got the car all together yesterday and went to start it. Just cranked, I checked fuel and had fuel. I then checked spark which was also there. Then as I was going over the wiring I found that the maf was hooked in wrong. Power and grounds were switched. Fixed that and the same problem no start. Then I checked the cam angle sensor and holy **** it was off. We just got this engine from Nagasaki motors and the cam angle sensor was on wrong. I thought to myself that was a dirty, dirty trick. I matched up the dark marks on the chain with the marks on the gears and aligned the cam angle sensor right. Stuck it in and it fired right up. The problem now is that its running extremely, extremely rich. It keeps fouling out the plugs. I am using a hks afr to tune out the z32 maf but no matter what I do with it, it doesn't seem to make no difference. If I unplug the maf sensor it runs the same. But its getting the 2 grounds, 5 volt reference, and the 12 volt signal. I just can't figure out why its running so damn rich. Can a fugged up cam angle sensor do that? I have a brand new one in a box in my brothers room if thats it. Did we fry something when he hooked up the sensor wrong? (all the wire voltages checked out so I did not think this was the problem) Its extremely black smoke, I can't breath when I am around the car. I ohmed out the coolant temp sensor and that checked out fine as well. Is there anyway that I could of put the cam angle sensor 180 degrees off? I need some help please does someone have and advice or past experiences they could lead me to something here.
Thank You
