need some advice
beingdevious
Car: s13, hb, white
what to do, what to do.
i blew up the ka again, slipped rod bearing. *not my fault* the guy i bought it from, put it back together wrong and the rod cap on cyl 4 was on backwards...
anyway. i just had the head to a machinist, completely rebuilt - $185had the intake to the machinist to be cleaned $20new #4 piston and rod $50new rod bearing setnew main bearing setnew gasket, seals, hoses, lines,new knock sensor.timing at 20º -- checked with timing lghtNGK iridium Plugs with < 5k miles89 octane, used regulalry
and the ***** still knocks!
i just dont know what else to fix to stop this knock. its all in time, the cams are perfect, its well oiled, it starts fine, runs fine, just knocks like hell.
should i A) keep searching for a solution or B) sell the entire KA2DE setup(motor, ecu, harness, transmission, EVERYTHING) and swap in something else with the money i get saved$$?
**note option b is kinda hard to accomplish since im poor**
silencer.1
Car: women, my car, paintball
What heat range are the plugs? Almost all the Iridiums I see are a 5. Try just some normal $3 copper plugs in the 6 heat range.
beingdevious
Car: s13, hb, white
ive been using the iridiums since they came out, they run great for me, and ive nevr had issues with them. this knocking started when the #4 rod bearing slipped. now thats fixed and it just wont stop
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
could have hurt the crankshaft
beingdevious
Car: s13, hb, white
thats what im thinking, a bent crank, but, there was less damage on it that the previous engine(same problem, last year) my dad thinks wrist pins
