Nismo_Freak wrote:Take out the 02 ... look inside the little slit and see if the ceramic "pill" inside is still intact. If its busted you need to get another one. On the S14 there is no timing retard or mixture change since the car will switch to using the secondary 02 from what I understand. You should notice the gain from 4000+ rpm. I noticed the motor pulled more up top with my install. All I have is intake, header, exhaust, and fuel pressure regulator.
Nismo_Freak wrote:That hollow cat is a resonator. 02 Sensors are around 60 bucks for our cars.
Yellow, the removal of the cat wont give a primary 02 sensor failure.
Jaeger if you cant see in the 02 you might want to clean it out. Get some Gumout Carb Cleaner and spray it in there. Its safe to use on the 02s.
