Need some advice on my setup. S15 turbo (250whp)
birdhou53
Advice on my new setup and maybe comments would be greatly appreciated.
First of all. My goal is a setup with pretty good response and something that will be as reliable as possible. Probably 230+whp
This is what I already have:
S13 Blacktop SR20DETFidanza Lightened Flywheel (11lbs), Not installed yetCusco Motor MountsStock T25ARC SMIC3 Inch Exhaust/Downpipe/Test Pipe/Turbo ElbowHKS SSQVKoyo Aluminum RadiatorStock InjectorsStock MafWalbro 255lph Fuel PumpMine's ECU (Boost Up)Circuit Sports Stainless Braided Turbo LinesCircuit Sports S15 Turbo Adapter Plate
The last thing that I am going to need is my S15 turbo which I should be getting in the next 2 weeks. Hopefully. I was wondering if anyone here has an S15 turbo with a setup that is similar to mine?
My question is... what is the response like on the S15 turbo? When does it start to spool and when does it make full boost?
The main reason why I'm going with an S15 Turbo is because I want a Turbo that's BRAND NEW for peace of mind as well something that will be able to help me make more power in the future.
Here are some pics of the stuff that I got:
Anyways, please comment if you could. Thanks!
cheapscheisst
Car: 1996 240sx w/ Kouki front end
uh... what's with the smic?
birdhou53
What do you mean? Just showing you guys some parts from my setup.
Shift_Tommy
Car: Nissan 240sx
ditch the smic and go front mount.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
cheapscheisst wrote:uh... what's with the smic?
thats a nice car, but that sig is waayyy to big change it.
cheapscheisst
done
partymonster 975
Car: 03 Maxima SE, 94 Corolla
well if your goal is only 230whp or a little more I'd ditch the S15 turbo and get the S14 T28, will be cheaper and it is ball bearing like the S15. Also if you want to you can spring for some S15 or other brand 440cc injectors and that should hold you till about 260-70 whp. I skimmed the list and the only problem is the SMIC, good brand but still. If you keeping it make sure your giving it as much air access as possible, like you can even drill holes on the bumper to get air flowing. Well you'll also need a Z32 MAF and an afc of some sort.
cheapscheisst
if you're only looking to make 230whp, that setup should be fine. just crank up the boost. just make sure the engine doesn't knock b/c you have a sidemount.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
T25 is plenty good for 230 WHP.
cheapscheisst
oh and as an afterthought you should think about buying an megan exhaust mani. they are dirt cheap (around $150) and can produce an extra 10-20 whp depending on your setup. plus you will spool a bit faster.
partymonster 975
cheapscheisst wrote:oh and as an afterthought you should think about buying an megan exhaust mani. they are dirt cheap (around $150) and can produce an extra 10-20 whp depending on your setup. plus you will spool a bit faster.
Not saying ur wrong or anything but 10-20whp, are you sure? I heard that they add very little hp at all. Can anyone back this up, just wondering.
cheapscheisst
from what i've read, the mr ex. mani is very similar (performance-wise) to an extrude-honed stock mani, which is supposed to give those gains. i could be wrong though.
brandonb012
Car: 91 240sx
i didnt think it gave hp gains, just faster and better spool times
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
You'll have aleast 230whp with that setup..Stock Turbo,Injectors,MAFS...And the ARC SMIC are good up to 14psi with a T25.Easy....I see no need to get a S15 turbo..I mean you have a Blacktop so your stock turbo cant be that old,Im sure it has lots of life left in it..Spend you money else were..LIke on a aftermarket headgasket and some valve springs and Rocker arm stoppers...Now thats peace of mind..
cheapscheisst
exactly... better spool times = midrange hp gains
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
man if ur running the stock T25 crank the boost to 12 psi and thats all u need for 240-250 whp.
Stock mani is plenty good and the T25 spools so quick u dont need a fancy tubular manifold.
birdhou53
Hmmm, thanks guys! I've decided not to go with an S15 turbo anymore. So that means that I have quite a bit of spare money right now. I was wondering if you guys think it's worth going with the Greddy VSPL? I'm trying to weigh the pros and cons of going FMIC or keeping my ARC SMIC.
I know that the SMIC is lighter and also less obvious to cops and stuff.
Has anyone here gone from a SMIC to a FMIC? Did you notice any difference in response, power, more lag?
JamesDaltonATP
ive read that arc sidemount is quite a good intercooler. id say up to 300hp, you would have no problems with that piece.
Dtek
Car: 1989 Nissan Silvia
Tyrant Motorsports has some unbelievable intercoolers at great prices. The brand is Alchemy and their IC has some basic internal differences from the run of the mill Greddy, Garrett etc... Ask the proprietor what IC he runs on his big dawg street-class car.
redtop91
birdhou53 wrote:Has anyone here gone from a SMIC to a FMIC? Did you notice any difference in response, power, more lag?
The lag depends on the length of the charge piping. Response will be dulled slightly but 20 HP gains are with grasp with a front mount. Just buy an eBay special. No need for a flashy name brand FMIC here. Especially for 250.
otterman
birdhou53 wrote:Hmmm, thanks guys! I've decided not to go with an S15 turbo anymore. So that means that I have quite a bit of spare money right now. I was wondering if you guys think it's worth going with the Greddy VSPL? I'm trying to weigh the pros and cons of going FMIC or keeping my ARC SMIC.
With a FMIC running with very little boost (8psi) it might actually hurt you depending on the size of the intercooler. But if you plan on (and you should plan on lol) turning up the boost then you will be fine. Who races on low boost anyways?
mrzabala
Car: 93 Nissan 240SX SE Hatch
I got dibs on your arc smic. email me at [email protected] Goodluck with your build, cant wait to see the results.
cheapscheisst
DrifterProdigy85 wrote:Bump for Megan on the bottom mount manifold. It definitly gained me 20+whp over the stock manifold. Took my trap speeds up a decent bit higher too. Went from 114mph (stock manifold) to 117mph (Megan manifold). No spool difference but definitly helped in the top end.
ok my bad. no spool differences but higher hp
chicos240
Car: 1995 240 SX
RedTop, My set up is a s14sr20 in a 95 s14. Bone stock. I have a question on FMIC's. I am reading your post and I want to make sure I understand it correctly. You are saying that for 250hp an ebay special is ok? Does that infer that if you want to make anything more than that you should go with a name brand FMIC?
