need some advice my sr20det is smoking
motorboater
Car: nissan 240sx
i have a 95 240sx with a s13 redtop sr. and it is smoking only during idle, and it is a bad blanket of smoke when it does. and i would like to say kind of whitish but my coolant seems fine and smoke kinda smells like burnt oil.and it only does it after beeing ran for a while or hard. any thoughts would help
Modified by motorboater at 9:59 PM 11/16/2008
redsx13
Car: 93 240sx 03 350z
motorboater wrote:i have a 95 240sx with a s13 redtop sr. and it is smoking only during idle, and it is a bad blanket of smoke when it does. and i would like to say kind of whitish but my coolant seems fine and smoke kinda smells like burnt oil.and it only does it after beeing ran for a while or hard. any thoughts would help
man, you really shouldn't double post like that , but here it goes again.......
Firstly, you want to run a compression test, its really easy on an sr and if you dont have a buddy with a tester you can buy one at your local auto pars store for under 30 bucks. This will tell you if your rings are burnt.
Its strange the problem only happens at idle, cuz the first thing that i was thinking was turbo. even so, it might be a good idea to pull off you intake pipe and check the play on you turbine (both back an forth and side to side)
Worn out valve guides can also cause you to burn oil, although sr's rarely suffer from this issue.
If its not any of thoes, you may want to rethink the problem, you may just be running rich at idle, it is a very typical issue for sr's. Although i havent seen it produce the amount of smoke to the extent you are describing. and unfortunately theres also a whole mess of components that could cause an sr to run rich.
good luck
motorboater
Car: nissan 240sx
yea sorry bout the double post i couldnt get onto my other account so i had to start another one. i was thinking valve guides but if that is rare than thats good. but yea it does it at idle mostly right after it is run hard. but i will check the turbo tommorow. thanks for your input
redsx13
no problem. But after you check that turbo, you really should run a compression test.
just keep us posted
fast_s13
my guess would be turbo going out or rings but what do i know
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
It's your turbo. If your rings were bad enough to cause smoke, there would be a constant plume at all rpm.
mjmmx6
Car: 1991 Nissan 240sx sr20det swap, 1993 mazda mx6 Fully Loaded
recomend a compression test asap
motorboater
Car: nissan 240sx
well i did a compression check today 150 across the board. i think that is normal isnt it. now that i look i kind of think it is burning rich at idle. cause if i raise the idle to like 1500 it wont do it. still havent got to check shaft play cause i need the gasket to check it. any thoughts
redsx13
motorboater wrote: still havent got to check shaft play cause i need the gasket to check it.
motorboater
Car: nissan 240sx
the inlet gasket?dont i?
motorboater
Car: nissan 240sx
any othere advice?
TurboZenki
Car: 1995 Nissan 240SX
I had the same problem with my S14 SR. For me it was my T28. At first it only smoked at idle after i ran the car for a while. The smoke was a whitish blue. Then after a while it began to do it while i was driving. Eventually the smoke became very thick and then the turbo blew.
exhsturbine
Car: 1997 240
hmmmm..... hows the crank case ventilation? anything clogged?
motorboater
Car: nissan 240sx
what you mean about the crankcase ventilation?
exhsturbine
Car: 1997 240
its happened to me where i accidentally routed my catch can wrong, or the pcv valve on other cars was super clogged, and lots of white smoke came out.... just thought id ask....
motorboater
Car: nissan 240sx
i have a catch can on it. but i have had it on for long time. and the problem just started this month. and i have checked the catch can and it is barely got some in it. but i will double check all the lines tommorow.
exhsturbine
Car: 1997 240
eh more than likely not it, just throwing it out there.... figured it would be quicker to check than shaft play...... (without the sexual implications)
TurboZenki
Check the turbo man. There is a good chance it's the problem. Just unbolt the air intake from the turbo and feel for shaft play. If there is a good amount of shaft play you have found your problem. You shouldn't need a new gasket.
CMG
Car: 1989 240sx Hatch w/ Redtop
Might just be a little blow by, unless it does it all the time.
impact240sx
Car: 1993 240sx Sr20det Gt2871R 2003 350z 1991 240sx Sr20det 2004 Land Rover DISCO
Turbo, i had the same problem and a trip to pitt and a 100 dollars later and my car was mint. Blowby really doesnt make it smoke, i had straight up oil in my front mount from blowby and my car wasn't smoking.
motorboater
Car: nissan 240sx
what you mean a trip to pitt and a 100 dollars later
motorboater
Car: nissan 240sx
and the intake is conected to the inlet adapter. witch has a gasket between that and the turbo
TurboZenki
motorboater wrote:and the intake is conected to the inlet adapter. witch has a gasket between that and the turbo
The gasket should be fine if you take the inlet pipe off. I took mine off and on about 10 times and the gasket never broke or anything. Although if the gasket were to break you could get a new one from Courtesy for less than $15 shipped.http://www.courtesyparts.com/t..._8692&
impact240sx
motorboater wrote:what you mean a trip to pitt and a 100 dollars later
Oh, i drove to pittsburgh and bought another t25 for 100$.
motorboater
Car: nissan 240sx
well no some more crap happened and i dont know what. the vacum is only at 10 and i think it might be because my turbo went all the way out and broke. it is spuddering and i guess you could say loping really bad. and black smoke is coming out exhaust. not pouring out just coming out steadly. any ideas?
Ari G
Rebuild time
