elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Oct 21, 2004 3:42 pm
If anything a wider tire like the 235 would decrease stopping distance, because theres more contact area, assuming all things the same (tire composition, ratings, treadware, etc)
Your injectors, as brian said are pintleless... Im not sure what the latter design is termed, maybe someone could enlighten me! But you want a fuel rail flush done, not an intake fogging.. Before you possibly waste your money, neither <!> will really affect your driveability problems... Trust me, been there done that.. Maybe a little, but your problems are elsewhere and probably more expensive .. Think knock sensors, timing and so forth......
One of the cat converter heat shields is probably loose... I had one on my older Q, and I kinda jury rigged it to make it stop by wedging a screw in there so it woudnt be loose.. later, i ended up going off an incline too steep and it ripped it off anyway I dont recall what rattles you have!
I dont tihnk fluid change will help the leaks... Maybe you could find someone with a used one that doesnt leak, to replace yours with... Since I remember keith saying they last pretty much for life as long as they dont leak.....
