sweetie6116https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113need small white brackets for driver's small rear window.Wed Mar 31, 2010 7:18 am
Postby
sweetie6116 »
https://forums.nicoclub.com/sweetie6116-u140159.htmlWed Mar 31, 2010 7:18 am
I got a flashlight and looked down in the mechanism and found that the hard plastic guide thingy was broken and the window won't stay on track to go up. I saw the piece had fallen to the bottom but I really dont' think any type of glue would hold it.
Ideas anyone? Is there some glue that might put the two white pieces back together?
Postby
AZhitman »
https://forums.nicoclub.com/azhitman-u113.htmlWed Mar 31, 2010 8:02 am
Easier to just replace the assembly (which isn't really "easy", but if you're gonna go to the trouble of removing the window, may as well make sure it's not gonna break again).
I used to have a pair of these windows, let me check my garage.
Postby
wmdavis007 »
https://forums.nicoclub.com/wmdavis007-u35898.htmlThu Apr 01, 2010 6:25 am
This is a common problem with our cars and the parts are not available from Nissan. Here is a link that will show you your best way to fix this problem:zerothread?id=383252Good luck....I'll be doing this fix again very soon cause my other rear window guides broke. It's a pain in the a** but worth it once they are fixed.
