Need shop information who can swap ECU chip
akikod
Car: 96 240SX
I got problem on my modified ECU and replaced to stock one.However, I still need to tune this ECU to match up the modsthat I got on my engine. Can anybody tell me the reasonableshop who can replace the chip or modify stock ECU to muchup the mods ??? I live in Tennessee, so the closer shop is better.
ashibah83
Car: 93 SUPA BLACK COUPE
learn proper grammar and punctuation. THEN maybe you can find out who can tune your car
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
ashibah83 wrote:learn proper grammar and punctuation. THEN maybe you can find out who can tune your car
This coming from someone who doesn't use commas. Is flaming all you do? Help people or GTFO.
akikod, you can go to jimwolftechnologies.com They Rom Tune ECUs by mail. You email them a list of your setup, pay them, and then mail them your ecu. They'll tune it, and mail it back to you.
-----------------------------------------------------------------------------------------------EDIT FOR ASHIBAH83
ashibah, this is a copy/paste from one of your threads you created. Since you decided to be such an a** clown, I figured I'd go ahead and show how much of a hypocrite you are.
so i went to my friends shop today to tear down my ka24de to start getting things rolling. i got the engine from a local junkard for $200, complete longblock, when i got the motor i was told that the car was was junked because it wouldnt start due to a "timing issue" and a "mechanic" who worked at Advance Auto Parts part time was trying to get it running but the car got towed because it was abandoned in front of the store, i cleaned it pretty good, took off all the accessories, oil pan, valve cover, and upper timing cover, i was working on getting the tensioners loose and after the uper one came loose i noticed this......i think i found the "timing issue", haha
1) Learn what a capital letter is.2) Learn what a run-on sentence is. (If you actually need me to point the one out in this, I'll do it for you.)3) Learn how to use an apostrophe in your contractions.4) Learn how to use a comma a little more often. (There are SEVERAL places you are missing them)5) The proper phrase would've been "I cleaned it pretty WELL"
Modified by PyR0NiAk at 11:55 PM 11/3/2009
Modified by PyR0NiAk at 11:56 PM 11/3/2009
akikod
Car: 96 240SX
ashibah83,
You may be right. I'm not a primary English speaker andI am learning it, my grammar should be wrong.
So, please egnore any of my threads, since I figured youare not the right person that I would like to communicate.
PyR0NiAk,
Thank you for your advice. I have just visited their URL,then. jimwolftechnologies.com logo showed up. It seemsthis is a search engine. Is there any specific link that Ineeded to jump ?
Please advise.Thank you, again
PyR0NiAk
I'm sorry. It's http://www.jimwolftechnology.com
I was thinking technology was suppose to be plural in the address. There's the correct one though.
