Need serious info MAF?
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
Ok guys i need a bit of help.Very soon ill be running a t04b (T4) turbo with a HKS SSQV ,Tail 38mm wastgate,FMIC, 3' cat back.What i need to know is if 480cc injectors will be good for a hacked maf setup and how can i tune it once i put this **** on?
Warped
Update: ill be running about 7-9 psi i have no boost controler and my wastegate will be set to 7psi so i wont be going over that at the start.Will i be flooding my engine or will i be doing ok.
