nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Mon Feb 04, 2013 12:46 pm
When was the last time you cleaned your throttle bodies? 22yrs on mounts, they may look good, but lift the engine up without disconnecting the mounts, guarantee they will separate. Rubber deteriorates after so many years, bad mounts will cause it to buck and /or shake, especially in first. This is when the most torque is place on the car.
I had another thought, does the shaking ONLY occur when you release the clutch? If it does, how old is the clutch? What brand? Did you have the flywheel resurfaced? I have seen and felt horrible chatter from a burned disk on a clutch, it will cause the whole car to shake, and would only do it in first gear. This normally happens to a clutch that is poor quality or from riding the clutch, it will glaze or burn the surface of the flywheel.
nissanfreak12 on Mon Feb 04, 2013 12:55 pm, edited 1 time in total.
