Thanks, yeah already checked the alternator and it's working just fine. Actually trouble shot this problem and realized that it is the relay for the power to the fuel pump. When it kicks in at idle it pulls to much voltage away from the car and does not stay on. I THOUGHT THIS WAS WIERD...but i do have alot of amps and other gadgets and the ignition switch to power on so i figure it is not getting enough juice. Thinking of running a direct lead to the battery on a switch or something along those lines. We will see...But if any one has any suggestion i'm all open to themR-Yahne_240 wrote:well the battery is not the problem i have a sr in a s13 and im using a lawn and garden battery!!!!!1
your problem maybe the alternator??????? that normally keeps the battery charged!!!!!!!
is the car idleing at 950rpms if not check for a vac leak sometimes that will cut your car off
do you have a mulitmeter??????? if not buy one
and if you can't use it call a buddy check to see if your alternater is cranking out power if not buy a new one
when your car is on check the battery if its under 12v your not charging
just a lil 411 maybe that will help
