Hello, need some help with oil seals. Replaced timing belt about 3 days ago and had the great idea of using some crappy a$$ chinese seals for the camshaft/crankshaft seals and now at least 1 of them is leaking badly.
I called the local dealearships but none of them have the oem part 13042-16V00, but I called this other store and they seem to carry some National brand seals. According to the part sticky the part I need is 224052, but they actually have the part 223420, which rockauto.com states should work for the Camshaft Seals on the CA18DE (see following link)
http://www.rockauto.com/catalo...up,20
Can use this without issues? AND are the Camshaft seals the same size as the Crankshaft Seal. Would rather replace all 3 and forget about it once everything is redone.
Thanks in advance,
