compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Mon Nov 19, 2012 11:11 am
Basically when it comes to wheels there are 2 terms used to figure out if a wheel will fit. ”offset” which is any direction further in or out a rim is from the center. .... Or ”backspace” where a given rim is given a number of inches from where the rim meets the hub to the back of the rim.
Example 8” wide wheel with 0 offset = 4” from center both ways.
8” wheel with +35mm offset = wheel pushed into wheel well 35mm. (35mm away from fender, 35 mm toward strut)
In your case with a 0 offset it's quite simple, take your wheel off and measure 4” away from hub and go straight up and that is where the lip of the rim will be in the wheel well.
-camber can help with more clearance as well as ride height and tire stretch.
if you know what your doing, you can actually have the rim past the fender without rim or tires rubbing.
