Need rotor help!
realization
Car: 2003 Infiniti M45
I have found the info and thoughts here to be such a great resource.
I just purchased a 2003 M45 30K mi base model, and it is screaming for new rotors and pads. They are worn in ways I never knew could happen. Being as it was driven in New Jersey and Michigan, this really shouldn't come as a surprise though.
I have been looking for a set of cross drilled rotors and really have not had any luck. Does anyone have a suggestion for a high performance front and rear set of rotors?
Thanks
cremecreme
Car: 2003 m45
I have seen some on Ebay...i think a few have ordered them...they have cross drilled and slotted rotors....mine are screaming for some also...if you get them do a DIY for us....so when can know tips on how to do it
cremecreme
Car: 2003 m45
wow that was my 100th post sorry i had to point that out!! I love the M
Q45tech
Important to consider that drilled and slotted are mostly a street fashion statement not a performance enhancer.
So many people sell so many low quality [metallurgy] rotors as it is difficult to know when you are getting something even up to oem quality...........whether it is possible to exceed oem quality is open to debate.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Get the Stillen Drilled Brembo from Joe. He had a specail on them last fall.
They are far superior on the front of my G50.
http://www.infinitipartsusa.com
OEM pads only if you are not autocrossing or tearing down mountains. Have the shim kit on hand just in case.
