need recommendation on wheels
Shiryuu
when i bought the car (93 coupe), it came with the sportmax 002 15 x 8 with 0 offsets. the wheels stick out like 1.5 inch all around. i understand that some may like this style, but that's not my cup of tea.
so i sold the sportmax 002's and now i'm running on some steelies that are borrowed from a friend of mine. but eventually i'm gonna have to give them back.
so i need some recommendations from the experience 240 owners. what wheels should i be getting if i'm trying to go with 15, 16 or 17 x 8 that has like a +30 or +35 offset that still has the 4 x 114.3 lug patterns?
i've thought about doing a 5 lug conversion, since it would be easier to find wheels, but i really like to just stick wtih the 4 lugs for now. so what do you guys recommend? thanks.
i240sx
Car: 240sx coupe
sportmaxx 002...002 look nice with slam s13 how much you sold your 002 for? order mine 530 out the door...
S13Teddy
Car: R32 Skyline, S13
Ugh, why would you get any wheel with a +30 offset? When will people start to realize that those offsets look like utter crap.
If you want your car to look ricey / mediocre, get offsets 25 and higher.
If you want your car to look decent, get wheels with offset lower than 25.
You should have kept the 002s and lowered the car.
Dittoz7
Car: 1997 2f0WtY SE!
i240sx
Car: 240sx coupe
S13Teddy wrote:Ugh, why would you get any wheel with a +30 offset? When will people start to realize that those offsets look like utter crap.
for once i agree with hello kitty.....
ViolentRunning13
Dittoz7 wrote:http://www.rbwheels.com/index....6a58d
Roll, Camber,
Those don't even look like they need a roll nor camber.
Dittoz7
Probably Not.
Trying To Get The If They Don't Fit....Make Them!Point Across.
W/e
S13Teddy
Dittoz7 wrote:Probably Not.
W/e
Then you should have used something like this as an example, silly goose.
Dittoz7
Shiryuu
thank you for your input.
the car is lowered on tein basic coilovers. i didn't like 0 offset because it stuck out too much and i rub every time i go over a bump on the freeway.
i don't want to roll the fenders or get huge negative cambers in order to clear the rub issue. i just want some wheels where it would sit nearly flush and not rub.
ViolentRunning13
Ugh I want those for my rears. Wonder if he'd trade for a white wheel.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Sounds like a plan im actually selling some Kosei K1s that are bronze if you want to buy them... they sit pretty flush and do not rub at all let me know...They are 16x7.5 with a +22 offset
Tsukiko
Car: 1990 240sx fastback KA24E
whoa. whoa. ok calm down. dont do anything... crazy.
First off, What tire size are you running on the 002's? if you are running a tire that has no stretch, its not going to help you in the tire rubbing department... um... actually...Ya know what? If you decide to get rid of the 002's, give them to me! I'll pay the shipping EDIT... **** you sold them. nm.
Modified by Tsukiko at 11:16 AM 1/9/2009
Dittoz7
He Already Did...
S14toRPS13
I agree. I've seen these on 240's. They're the fit that you're asking for. Not +35 offset.
urcaptnspeaking
Car: 2007 Ford Fusion
2001 Honda Accord
1978 Pontiac Trans Am
I agree with teddy here. DONT buy anything with that high of an offset, itll look sunken. Stay around 12-25 area, and you shouldnt rub.
S13Teddy
If you are lowered, the 002s should not rub at all if you run 195/50s. This is with minimal camber.
This is an old picture of my car. In this picture, I am using a 5mm spacer in the front with 195/50R16 tires. In the rear I am using no spacer with a 205/50R16 tire. They fit perfectly. They did not rub.
240lookis
Car: 1990 240sx hatch
some people just dont know **** about wheel fitment.
002's have great fitment.
urcaptnspeaking
2001 Honda Accord
teddy I love your car. paint your wheels pink, or neon green or yellow.
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
^hes far past that point.
Sport max 002s fit fine. You are on stock suspension im guessing so thats why its gay as screw.
I will NEVER put anything higher than a 30 offset on ANYTHING I own.
I ran the 002s 15x8 +0 on my Scion XB. **** fits great with a 195 on it and a bit of camber.
My new wheels for it are also stupid low offset but even wider.
Theres no excuse to run **** sized wheels on your car. Man up.
If it rubs, stretch a tire, or camber it, or roll the fender. Dont just ***** out cause a year or two down the road you will be looking at your self like "why the screw was I so gay"
S13Teddy
white90esex wrote:Sport max 002s fit fine. You are on stock suspension im guessing so thats why its gay as screw.
He is on coilovers! He had no excuses!
simmode1
Car: Red '95 S14
I have a set of these in silver. But mine are 16x8.5+27. Gonna put a 30mm spacer in the back and a 7mm spacer in the front. Gonna be nice.
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
what r u going to use them for... show, drifting, yada yada
