Dennis, we both know, most of what I know i learned from you and your posts, but plz consider this:
yes, the extra travel is extra 15% travel on the rings, but IMO that should not equal 15% less engine life.
this is why:reduced engine lugging around town due to the higher rear diff.
Also, didn't you once point out to me, that bearings are more of a limiting factor to our engines lives as rings?
The reducing lugging in town w/ the higher rear, the reduced lugging in OD on long interstate hills should all make this easier on the bearings right?
Also the reduced lugging should be good for ATF line pressures too right?On long interstate hills or in town, now with the 4.11/4.08 I donrt have to feel guilty about leaving it in "D" anymore.Also at the higher rpm teh oil pressure will be higher helping to squeeze more oil into the space between rings and cylinder walls (or at least at higher pressure).This should also help offset some of the penalty.
I wouldnt be surprised at all, if the life reduction of the rings is much less, than that which one would mathematically predict from the increased travel due to shorter rear end.Adding to that the pleasant side effects oif less luggin on engine and transmission and the only real draw back seems mpg's.Around town the mpg penalty should be small maybe comparable to leaving it in "3" vs "D" which I do all the time anyway.As for hiway driving, I will report in detail my consumption w/ a short rear diff.
Fred...
