NEED Radio/Nav removal instructions for 2003 G35 Coupe
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
I'm about to install a IPOD adapter on my car. I need concise instructions on how to remove the radio to access the rear of the radio. I did a search and did not find anything here.
Help please.
Gimli G35
Car: 1996 Lexus ES300
jeez , everyone is needing links i had saved before my computer wipe..
Ill find it later when i have time
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
Nevermind - I got the info from the vendor.
I've gotten everything apart and have tested the ipod connection. I'm stopping only because it got dark. Will finish up tomorrow.
This is likely the only interior mod I will do - I'm glad to be getting use of my ipod again.
azn_dynasty69
Car: g35
hey i wuz wonderin how did u take off the dash/center head unit console....i want to install a dvd player n monitor but also keep the stock head unit...i almost took off the center console but the top part wont come off n wusnt sure if there is another bolt or do i have to pull it harder to get it off...thanx
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
This was a very involved install - but you begin by removing the trim piece around the clock, remove the clock, there is a bolt behind the clock that holds the a radio/ AC assembly to the car. I also had to remove the center transmission console cover and shift nob. I got mine installed and have the ipod in my center console - unfortunately I will have to do the install over because the IPOD is transmitting music but not getting recharged. I also made the mistake of removing the air bag plug which means a trip to the dealer to reset the error code.
I found some instructions on an ipod site I can try to find the link.
gottarex
Can you please post that link. I've been struggling to take the dash off
azn_dynasty69
Car: g35
this is wat he gave me...
echau
can anyone help me with taking the console out? i want to see if i can unjam a cd from the cd changer...
any information is appreciated. thank you.
Return to “G35 and G37 Interior, Exterior and Audio”
