Darius wrote:I installed the R33 clutch pedal but it doesn't fit very well. It bottoms out on the floor before it achieves the 4.5 inches of travel in the 240 FSM. I just spent the $40 and ordered a new one. I'll sell you mine if you really want
Did you use the master cylinder from the R33?! What all did you use, OR, can you tell me what works from the R33 to work with an S14?
Also, did you cut the brake pedal, or use the R33, or an S13 or 14 manual brake pedal?
thanks..
Modified by FriedEGs at 1:57 AM 1/21/2006
Modified by FriedEGs at 1:58 AM 1/21/2006
