loystock »
https://forums.nicoclub.com/loystock-u10145.html
Wed Apr 21, 2010 10:05 pm
Which car and model year?
Did you check/replace the fuel filter? How about the fuel pressure - 34 PSI with engine running (vacuum on) and 43 PSI with ignition ON but engine OFF (or engine running w/ vacuum disconnected)?
Ensure your battery connections are clean and tight. The battery voltage must be >12.5 VDC. A weak battery can crank the engine but the speed may not be enough for combustion.
