need quick reply rear camber problems
timderiksen
Car: 1998 Q45t-wanna be cima
im about order the upper rear adjustable control arm for my 98 q i just need to make sure its for the 240sx s14. i need to make sure that it will fix my camber problems. tomorrow im puttin 20's on the car and i dont wanna eat up tires like crazy. also were would be the best place to find the control arm I need them fast
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I've already tried the SPL ones and they don't work, either model.
Others have said some other brands work, but no proof to date.
I'll talk to SPL tomorrow. If you participate, I think we have 4 firm orders. they wanted ten paid, but I'll see.
If your car is lowered, eiven with the Eibachs, camber will eat the rear tires at 2 degrees negative.
timderiksen
no the car is not lowered just gonna be sitting on 20's
i saw the ruca do they fit
https://www.upscaleautomotive.....aspx
timderiksen
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I never have seen the evidence any of those fit.
It seems the spring seat on the shock is much lower than on any 240SX and this is what interferes with those arms.
timderiksen
what will work then
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The custom SPL ones if they will prototype them for 4 of us.
I'll talk to them tomorrow. You can email me.
timderiksen
that sounds nice and all for them spl's but i need somthing fast i was looking at my up control are and it looks like one of thes should fit
http://www.240sxmotoring.com/reupcoarmr.html
let me know your comments if they dont fiit **** im a welder ill make them fit
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
timderiksen wrote: let me know your comments if they dont fiit **** im a welder ill make them fit
Then the best sollution would be to weld in about .25".
But I think the upper links are forged steel.j
timderiksen
yeah i really dont wanna start cutting in to the stock control arms but **** if i have to i will i can tig all if i do it and it works **** i could make some money haahahahhahaha
timderiksen
the ones you tried how did they not fit????????
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Spring seat interference as stated above.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Brian, were the 2 models you were talking about the 1/2 circle and the full circle?
what is SPL thinking about changing?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes. Rotating the inboard mount down by 10°.
unknown007
Car: White 1993 Q45 (G50)
If im correct the Z32 has the same suspension as the Q45.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
unknown007 wrote:If im correct the Z32 has the same suspension as the Q45.
It's similar to the G50, nothing like the F50 or FGY33 front.
Back to reading the FSM!
unknown007
Thats what i meant lol i forgot he has a 98 i got a G50.Lol so the s13/s14/z32 ones fit on the g50 right?
I already read the FSM i just didnt know the year i forgot.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Z32 RUCA on the G50 are usually a go. SPL work.
unknown007
would an iron ruca be good?
Sounds sketchy
unknown007
do s14 camber arms work?not the ruca but the arm?s13 rucas?
timderiksen
does anyone know what arms fit 98 q i need them really bad. has anyone had any luck with any brand?????????????????
timderiksen
does anyone else fixed this problem???????????
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
timderiksen wrote:does anyone else fixed this problem???????????
Bueller??
unknown007
this is what a 97 Q45 on VSC has also is bagged.
-S14 rear upper control arms, still a lot more room for more camber.-S14 rear lower adjustable toe arms.-S13 front adjustable toe arms.
so there's you options good luck.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
unknown007 wrote:this is what a 97 Q45 on VSC has also is bagged.
He is looking for a solution for stock spring mount seats.
His car is not "bagged".
unknown007
maxnix wrote:He is looking for a solution for stock spring mount seats.
I know i was talking about the camber arm choice not the bags.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
And once again I am telling you it will not work because of the location of the lower spring seat on the OEM style rear shock.
You were speaking of a "bagged" set up.
We are not!
timderiksen
guess illl just cut my control arms and half and make them longer by a 1/8 inch or so what would you suggest anyone?????
unknown007
maxnix wrote:And once again I am telling you it will not work because of the location of the lower spring seat on the OEM style rear shock.
We are not!
Wow doesn't matter you can adjust the control are to OEM specs.Or atleast close.Doesn't have to be bagged.
unknown007
timderiksen wrote:guess illl just cut my control arms and half and make them longer by a 1/8 inch or so what would you suggest anyone?????
Sorry i can't help but im done with this thread.Good luck hope it works out.
