Need quick help from someone with Manual SR20DET
SpeedRacer1
Car: 1990 240SX, G35
Anyone with a manual redtop Sr20det can you check your Throttle position sensor and tell me what order your wires are in going into the tps on the throttle body side, not the harness side. If you could tell me from the top (hood) to bottom(ground) what color order they come in... I put white in the middle but am not sure if i got the other two correct. The car seems to be ok with whatever i put but i need confirmation.
SpeedRacer1
Well it looks like no one knows or is too lazy to look at their engine for a sec. So i will post what i could figure out for anybody who searches this in the future. Looking at the TPS (throttle position sensor) from the drivers side, the wire at the bottom left should be black, the middle is white and the upper right one is green/red.
