ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Sep 01, 2011 7:36 am
Is your existing radiator copper brass or aluminum. In either case get it recored, the result will be a new radiator as good as the OEM because it will be an OEM.
Get pricing to repair, shop around, look at the shop, does it look prosperous?
A rebuilt rad should leave you with a good rad, make sure they offer a decent warranty on their work and get a print out of the final test results, pressure, BTU, flow.
