es sex0727 wrote:so i just got my car all sorted out with my water pump, or so i thought. wel now i have a weird little issue, when i shift sometimes from 1st to 2nd and 2nd into 3rd and rarely from 3rd to 4th my rpms will stay up no matter the rpm range i shift at. my car also sometimes idels at like 2 grand too high right. it makes for some uncomfortablr driving. my initial thought was my throtte cable is sticking but i looked at it and it seemed to be fine but i really dont know what a proper working one looks like. should the cable be tight or have a little slack or bend to it? i dunno. also when i was doing the water pump the throttle body looked a bit off, should that make a 90 degree angle with the wings and the body its self or is it okay if its at a slight angle?
Sounds like you may have answered your own question. I don't know exactly what you mean by the throttle body looking a bit "off", but the butterfly should be predominantly closed when idling. If it has excessive gap, there's your higher idling problem. Do you have cruise control?
