need poppop
93 Q45
Car: 93 INFINITI Q 45
any one point me in his direction
93 Q45
getting 17 to 22 ohms at injector harness on all pins
goody90q45
Car: 1992 Infiniti Q45 (sold)
With engine hot or cold?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
hot or cold shouldnt matter!!!! Did you have any of the interior lights, radio, etc on or anything electical on the car, ON? if you did, that will throw the reading off, also if your battery in the meter is low.
93 Q45
no nothing else is on getting code 45 leaking injectormeter is good testing all pins getting all near same readeingsengine was warm just traveled 50 miles
93 Q45
second set of reading on cold motor
i have 5 reading 14.7 to 19 ohms it fluctuates up and down on all 5i have 3 reading 19 to 23 ohms so i guess i need all 8 right
elwesso
2007 BMW M Coupe
im thinking your meter is goofy.. you shouldnt get fluctuating numbers....
Is the engine running rough??? most of the time if your engine runs smooth but your getting injector leak its the o2 sensors.
93 Q45
rough the thing acts like its running on 3 cylinders
and it starts right up butt stumbles all over and will not accelerate
above 2k and you have to pump the gas really hard and fast to get that
ill keep you guys posted on what i find ill be tearing it down this week
wish me luck
93 Q45
pulled the plug off #8 ohm reading is 15 steady
could the harness be bad the car has 248.000
i know the 15 is out of specs butt im not getting the fluctuations
as when i test thru the harness which leads me to think the harness is got problems also
elwesso
2007 BMW M Coupe
i think your going to regardless be looking at taking the plenum off and getting injectors cleaned or replaced (deatsh works, NICO sponsor)
93 Q45
i have access to a 94 complete rail assy and harness
w 60.000 miles on it i know the injectors are different
butt if i replace the whole rail and harness will i find any other surprises
or is this just not a option
elwesso
2007 BMW M Coupe
technically you should be able to use the 94 injectors with a harness change and chaging the little donuts in manifold. no one has done this, however the donuts are like $20 for all 8 so its not a huge risk...
93 Q45
i guess ill be the first to try
if i was putting in reman injectors id probably still have to change out the donuts being i have 240.000 and i dont think its ever been fussed withthe plenum seals how much do those go for
93 Q45
today i started the car,and all is normal. ohm reading are still out butt runs like before. no codes ,nothing.!!!!! whats going on is it possible ? i had water in the fuel. or something stupid like that. the wife had drove the car on E for quite some time then all this happened after fill up
