need picture of ecu...
rbforsale
Car: '92 Nissan 240SX S13 vert ka-s
i need a picture of the back of the ecu from some one for an rb20detso that i can see what color wire goes where in the ecudetails would be greatly appreciated 8)
Sil240
Car: Nissan S13 "The One Cam Wonder"
a picture is not going to help you.You don't have the complete harness with the big blue plastic connector???
There's like 200 wires and there only so many colors. There stripes and dotted ones and stuff like that. Plus they change color I believe further down the harness.
rbforsale
i have the whole harness and the master plugproblem is that when i had a wire short on me i freaked out and pulled all the wires out of the back of the ecu,stupid::whle smacking head::so now i have to plug them all back in but i dont know what wire goes where
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
If I saw this thread earlier I would have run down and snaped a few with and without the harness on. But Im actually off to work. If you dont receive one by the time I come back Ill snap a few for you. Later.
rbforsale
dude you are a real life saver!!!!
klh6686
Car: '92 FB stock daily
'90 FB w/ RB20
'92 FB w/ VH45
wow
rbforsale
???? what do you mean "wow"
Sil240
he probably means you got alot of work ahead of you.
Next time go for the neg Batt cable
Carl H
why would you pull all the wires out instead of being logical and removing one by one?
SeVa-S13
Car: '05 GTO 6spd
Carl H wrote:why would you pull all the wires out instead of being logical and removing one by one?
lol Carl's normally a little more helpful but I have to agree on WTF were you thinking?
If my RB20 wasn't about 3k miles away, I'd snap a pic for you. (you'll likely need quite a few, very detailed shots)I can't find the wiring diagrams in my R32 FSM but that's really what you need, combined with an easier-to-read pinnout diagram...atleast that's how I'd go about fixing that genius move.
rbforsale
if your car started smoking perfusivly from the kick panel,and you pull it off to find your wiring harness is ablaze what would you do?i panecked so please guys,lower the scolding rate... plus i was driving on the highway when it happend
Modified by rbforsale at 7:16 PM 1/23/2007
Carl H
i too have had a car's harness catch on fire but it was caused by a chaffed wire...i was driving at the time but i had sense to pull over turn the car off and pull the battery cable.you panicked and did what you thought was right...altho at this point sounds more like you need a new harness.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
Your gonna need the wiring schematics that references all the plugs and each wire with it's proper color code to pin these all back in together. Honestly i'd pull the harness and ring out each from each plug and pin them accordingly to the pin number on the harness plug. Best idea. Need more help i can't really help. I don't have anything for rb20's but if you hit up megallas website i'm sure he has something.
rbforsale
why cant someone just take a picture1 of the top side and one of the back side so that i can see both rows of wiresplz plzp plz plzp lzp plzp for the love of god!!
Gold Digger
Car: Current:
2011 Infiniti G25X
Former:
1995 Nissan Skyline GT-R V-Spec Midnight Purple
1990 Nissan Laurel Club S Turbo Two Tone Pearl
Patience is a virtue my friend. Maybe not everyone has a harness and ECU just sitting unused or in an easy to take position. Trust me, these people here will take care of you when they can get to it. It sometimes takes a few hours, days weeks.
I know in hindsight you realiz what you did was the wrong thing, but remember, "Improper planning on your part does not constitute an emergency on my part."
rbforsale
or if someone could post or point me to someone who has posted an ecu pinout with color designation,just a thought....
Modified by rbforsale at 6:45 PM 1/25/2007
rbforsale
sorry if im annoying you guys,my daily driver is down and have no way to work so im freakin out a bit
mello88
Car: s13
enjoy
a31 rb20det a/t ecu harness wire color pinout
See r32 fsm page EN-507 for pin out/sensor data.
Please save/redistribute this image. IDK how long we-todd-did will keep it hosted.
Modified by mello88 at 9:26 AM 1/26/2007
Stealth-Z
Car: 1991 300ZX
As a last resort, you may end up having to trace each wire with a multi-meter. On this link, Right click and save ashttp://www.fairladyzg.com/PDF/...l.pdfIt is the 22MB PDF file for the R33 engine manual. There are drawings of the pinouts from the ECU. Start by unplugging one thing at a time and use the continuity function on the meter. touch one end on the unplugged connector and start probing the wires pulled out of the ECU harness.
It is time consuming and tedious.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Mello88,
Man, that pic is awesome! Where did you find it? I'm thinking of creating one for the R33 RB25 S1 (unless there is already one available. I know there is one in the FSM similar to that, but just has numbers, I dig it because it has a pic and is color coded.
USMCgetsome
well done with that pic and the listing. I am stunned! Someone put in sometime on that Good job fellas!
skillzilla
I had an A31 RB20 in my old ride and the colors all matched up with the regular R32 RB20's from what I remember. That diagram should be good to go.
mello88
Car: s13
I just made it... I was working on my harness a few weeks ago and wrote down the wiring colors. Saw this guy needed the same kind of info so I just took a picture and copied my notes into it.
L0nestar, if you want to make one for the r33/rb25, I'll send you my fireworks PNG file to use as a template. Try to take your harness pic with pin 101 in the top left, it'll make it easier (check against the fsm diagram).
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
I lol @ this thread. If my kick panel was on fire, i got a handy fire extinguisher for it. don't you? cheap insurance if you ask me.
Stealth-Z
Car: 1991 300ZX
Great work...
rbforsale,Please buy this guy a beer! I think he deserves it!
rbforsale
dude you are a godgot my car running to daydont know how i can ever repay you!!!!!
mello88
Car: s13
Just do something helpful for the RB community when the time is right.. Glad u got it running again, peace
