Need pic of fuel pump relay please
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
Ok, I'm sucking up my pride and asking for someone to show me what the hell the fuel pump relay looks like. I've looked all over the place and can't find what I need.
I'm not getting fuel and the fuse appears to be good. Fuel pump worked just fine when I pulled the KA and I have GOT to get this ***** going ASAP as the Winged Warrior III is coming in just a couple of weeks and I'm in it.
Thanks for the help guys.
jr_ss
Car: 95' S14
Have you checked for power at the ECU? Find the fuel pump wire and put a volt meter on it. If you've got power at the ECU(12v) then you'll need to find the relay. I'm not sure where it is in the S13, but in the S14 its in the drivers side footwell, closest to the door I believe. There should be 2 black/yellow wires coming/going to that relay...
Repo Man
2003 Honda Accord
Cool. Thanks. I haven't checked at the ECU yet, but I will.
