onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Jan 06, 2006 2:26 pm
if you are gonna get it repaired right away, either will do. It will cause some uneven wear, but if you are only driving like 5 miles to the next repair station or something like that, no big deal. Also, you can probably get a tire size that will very closely match the 16 rims.
If you are a really anal person, you would buy another ssr as a spare and keep it in rotation to even out wear. Or maybe even 2.
Just make sure you keep that s13 alloy inflated because reg wheels lose air a lot faster than wheels made specifically for spare use.
Also, you may want to get a 5mm spacer or something to go along w/ the spare if your spare doesn't clear front rim (unless you want to replace good tire in rear w/ spare, and move that good one to the front when the front blows).
