NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Sun Sep 28, 2003 8:33 pm
I would consider that buying the rear rotors won't help performance unless your current ones are too thin. I think you could save a lot of cash if you just went with the front rotors, pads and fluid all around.
If you get decent pads like the masters, pbr r4s, ebc and change your fluid you will have little to no fade during auto-x, road-racing.
A major factor in braking is the tires you are using. For example, if you are using 205-60-15, you won't have problems. However, if you are using 245-40-18 Hoosier slicks, the tires will be able to have a higher grip threshold therefore pushing the brakes to a higher limit and temp.
