Need opinions on 400whp daily driven Sr20det
Max_444
Car: 1993 Nissan 240sx
Hey everybody
I need some opinions on my sr buildup. My car is currently getting built back in New Brunswick Canada and Im all the way in Yellowknife NWT so I can't really supervise the build up.. I have over 16k invested in it and I am wondering if I chose all the right parts to daily drive an expected 400whp car. Yes I know a 400whp daily driven sr20 is crazy, don't need to point it out.
Mod List
S13 Sr20detDownforce Performance Custom front mount IntercoolerHKS Hi Power ExhaustCustom 3,5" DownpipeWalbro 255lph fuel pumpGreddy RASBlaast Performance Custom T31/T04e 60 trim turbo (Rated 500hp+)Apexi Power FC with CommanderApexi Boost Controler (PFC)Bully X stage 3 clutchCometic Head GasketArias PistonsEagle RodsCustom Top mount ManifoldKoyo RadARP Head StudsHKS Stage 2 264 cams with valves springsHKS SSQV BOVTomei 2 way LSDApexi 720cc injectorsTial 40mm External WastegateNew oem water pump and timing chainNew main bearings and rod bearingsand other little nic nacs...
So would this setup be a reliable 400whp daily driver?...Or will I need extra parts? if so be my guess to point some out
Thanks in advance
Hijacker
Car: '92 240sx Convertible
'94 F-150
Max_444 wrote:Cometic Head Gasket
Seeing your list, this is what makes me cry...
Max_444
Yeah I know... my mecanic chose to take the cometic head gasket..but if it blows on me its his fault so..Ill get a new one for free haha.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
I have cometic in my car and am installing new cams. What HG would you recomend for me? Currently have stock bore.
Max_444
I recommend a HKS pr Tomei head gasket..or you stick with the cometic
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
COSWORTH OR APEXI
Hijacker
'94 F-150
Cosworth or bust for me.
Max_444
So im guessing I don't need any more parts?... Or will somebody point something out cuz I want to get all the parts so they can finish the build up
mistamacadamian
Car: s13
i dont see how cometic is bad with arp head stubs
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Apexi FTW. Hybridynamics and Mazworx run Apexi in there drag cars with way over 40psi of boost. Also a 400whp 240 isnt crazy to daily drive. Power is only there when your giving alot of gas. You drive it easy and its no big deal. I drove mine this year in 6" of snow.
kentuckyslider
You should be putting down well over 400whp if you want. I don't know your turbo, but it sounds like a much better set up than mine and i'm putting down 345.
DrifterProdigy85
just a 2871r .86 on a built block and ported head.
codyace
Car: S14 w/redtop
Max_444 wrote:Blaast Performance Custom T31/T04e 60 trim turbo (Rated 500hp+)Bully X stage 3 clutchCometic Head Gasket
Those are the only things I'd be timid/unsure of.
Kinda curious why your build went with an oddball turbo (not that it's bad) and some no name clutch...
And cometic sucks. I'd def get your builder to swap that out before you go to far involved.....
Kalypso
^ i agree, its an odd turbo choice
borg warner / holset / or garrett
good luck and enjoy the build should be a fun car.
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
switch the headgasket to apexi or something better then cometic. i have a whole thread started on the cometic and why it sucks!
Max_444
Yeah I know its an odd turbo choice...at first we we're going with the gt3071r but then a company in Montreal which was my turbo supplier could build me a custom turbo that surpasses the gt3071r and its a mix of a Garrett and Turbonetics housings with balance turbines and the turbo is ported and polished which they simply called custom t31/t04e .60 trim. They claim it spools as quick as the gt3071r and can produce over 500whp..but I don't want to run that high yet. Yeah Ill probably call my mecanic to switch de HG for an apexi. Thanks for help
Max_444
And for the ones that think the Bully X Clutch is a no name clutch well do a bit a research...Probably you guys don't get those in the states buts its a really underated clutch company form Canada and my buddy has a 700hp Skyline and he said it was better the old exedy he had on. They can build custom clutches for specific applications so we decided to get one specificly made for the car
Ilvemynissan
Car: 240sx s13
Hey did you get your build done? If so how is it? My friend is using a lot of the same stuff you did for your motor and I just want to know if everything went OK.
peetar
Car: 1992 Galant VR-4
I was always told that it is knock that kills head gaskets. With a good tune and ARPs there is no reason for a HG to blow.
Kalypso
Ilvemynissan wrote:Hey did you get your build done? If so how is it?
what happened
Max_444
No the build is not completed...Everything is installed and the car runs but needs to be dyno tuned (Car running too rich..shoots flames out the tail pipe)...It should be done around the 3rd of september or a lil later.
The only parts i added was a suspension modification ( Tein Coilovers ).
The guys that did the swap are aiming for 500whp on C12 or C16 race fuel (400whp on pump 91). If hp goal is not met they will add more parts to reach it but it should be possible with current parts. I'll let you guys know the outcome of the dyno pulls. Ill post the dyno run on youtube shortly after its done!
Kalypso
cool, sounds great so far
if you dont reach you're HP goals, complete your the suspension and tighten chassis rigidity. so all the power you have goes to the ground.
Like the Teins you just bought, multi link arms, nismo power brace, struts, and es Master bushing kit.
sldewyz
Car: 97' Danger Ranger
PICS OR FAIL.....
Rich
sldewyz
sldewyz wrote:PICS OR FAIL.....
Rich
^ rich you clown...
Ilvemynissan
Car: 240sx s13
Cool can't wait to see the dyno results.
Sabot
I want pics..
peetar
karmakaze
Car: 98 240sx SE
DrifterProdigy85 wrote:Apexi FTW. Hybridynamics and Mazworx run Apexi in there drag cars with way over 40psi of boost. Also a 400whp 240 isnt crazy to daily drive. Power is only there when your giving alot of gas. You drive it easy and its no big deal. I drove mine this year in 6" of snow.
mazworx runs a power enterprise HG now. i have one, its pretty dope.
Neil
Car: shooting laser guns
mistamacadamian wrote:i dont see how cometic is bad with arp head stubs
shouldn't need aircraft grade head stubs to justify the use of a crappy head gasket.
Kalypso
this thread is
