Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Sun Sep 06, 2009 2:52 pm
You never really mentioned your power goals. 18 psi on a GT28R is in it's efficiency range, but near the top of it. Also, it's ball bearing, meaning it needs oil AND water to cool it, so you will have to fab up water lines.
A stock rebuild is good, you shouldn't have any problems with the engine if you rebuild it correctly. You might want to get a new oem oil pump and timing chain kit, I'm not sure if you were including them in your rebuild.
I say you go top mount t3/t4. You can run a smaller t3 and have the same spool characteristics of a t2, and most of them only require oil so water is something you don't have to worry about. The JGS kit is a great starter kit and come with a downpipe and dump tube. I recommend it.
As far as tuning goes, you have a few options. You can get Nistune, which uses your stock ecu but acts like a standalone, and you can get an ECU tune like you mentioned. ECU tunes are easier because they are plug and play, but to get the most out of it you would want to fine tune it with your SAFC. Nistune requires you to get a basemap then drive to a tuning shop and pay them to tune it, on top of the cost of Nistune itself.
I have an EFI Specialist tune and it runs great. I don't have an SAFC to fine tune, but my AFR's are right where they should be.
If you have any more questions feel free to ask.
