VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Mon Sep 18, 2023 3:12 pm
You can actually even replace the bag without replacing the seatback. Nissan just doesn't sell them that way, but the bags are only held on by two 6mm studs, not welded or anything. They can all be disassembled and the bag replaced without replacing the frame or upholstery. Junkyard bags are never any problem as long as the wiring is intact, if the bag itself has any issues then the system will tell you about it.
Vis the P17F1, that's a "judder detection" code meaning the TCM (trans controller) has detected some minor slippage of the CVT belt. Serious slippage would be causing a P17F0, that's usually a death code. If the "proper maintenance" included CVT fluid changes at 30K intervals and the transmission has no symptoms, it may not be anything to worry about. If the CVT is on the original fluid or hasn't had many changes, get some fresh fluid in it right away and you can hope the Valve Body isn't damaged. With a P17F1 it's unlikely the belt and pulleys are damaged, so a new VB is probably the worst case, not a whole transmission.
