OnTheRoadAgain »
https://forums.nicoclub.com/ontheroadagain-u77276.html
Wed Jun 24, 2009 2:03 am
re: 91 Q45
I thought the car cranked a little more slowly this past week, but it was hard to tell since it starts so quickly... I thought I would go and have it checked..... alternator is about 2 years old... battery was 3 yrs old, terminals cleaned regularly etc.
so, yesterday, wouldn't start; put the charger on the battery for 2 hrs... still no start, no click nothing;
headlites did not even dim on "start" position.
odd, windows didn't work either, radio didn't work (I thought battery was shorted)
tested bad battery and installed installed new battery, same thing. (3 year old battery - to the month)
found 30amp ignition fuse blown (in engine compartment next to battery) ; swapped with another and blew again on "start" position;installed another, and now windows work if in "on" position, I'm sure will blow fuse again, if turned to "start".
so, starter? or ingition switch? (both?)
what do you think, I'm out of fuses and will have to rent a car today.
appreciate your help
(91 Q45)
