Need MegaSquirt driveable map
Thekingisin
Car: ???? Nissan S14 Sr20det
Any one have a Sr20det running a mega squirt stand-alone !!! I need driveable map asap !!! MS downloadable maps aren’t working my be my timing map please help
We have the idling and runs good till 2k then brakes up and timing gets off set we’ll reving up
Car is a 13 blacktop
MS Pnp2
Tomie head gasket
Arp studs
P2m coil packs
750cc injectors
T28 turbo a way
Aem boost control
Aem wideband
Aem 540 fuel pump
Reason: Revise Title
tunermt
Car: s13 ka-t running AEM EMS v1, Gallant VR4 Running AEM EMSv2, S2k waiting for the Haltech
Highly recommend you have the car professionally tuned. You do not ever want to try and a tune from another engine/setup and expect it to work without retuning it.
If you are planning to tune the car your self that great just take your time to fully understand what you are doing and tune the ecu don't just try to load other peoples calibrations and expect them to run the engine correctly.
