miamiheat3332 »
https://forums.nicoclub.com/miamiheat3332-u103568.html
Wed Jan 02, 2013 10:32 pm
I would try what town said first as theres no reason a bad iacv should do that. If its shot, try ebay, or junkyards,
You stated you have a 02 in your profile, on these cars with the ecu's your kind of limited compared to other cars where they carried alot of similar things for a few model years, the only ones that will work in yours are 2001-2002 ones with the vq35 engine.
And 03-04 99% sure will not work as they were designed with a DBW (drive by wire) system with electronic throttle control and not DBC (drive by cable) which is mechanical throttle.
Also if your getting one on ebay or junkyard, make sure it is spec'ed out exactly the same as your path meaning 2wd or 4wd, 3.5 engine, and auto or manual trans, although i dont think they offered manual in 02 but make sure the ecu you get isnt coded for manual and that kind of stuff.
