TopStreet240 »
https://forums.nicoclub.com/topstreet240-u7821.html
Wed Jan 28, 2004 9:08 pm
okay guys, its time to pool your heads together. I have a ka24et amd ot os pm 12psi. I have a problem which can only be describes as a full cut of power at different times under boost. The magic number of mph seems to be about 80mph and it happens most when shifting from 3rd to 4th gear, but it sometimes happens in 3rd and also in 5th gear. I dont know what it is, but it seems like i lose all fuel or timing or something, it is as if im hitting a limiter??? I have the fuel for the car so i dont think that is the issue (550cc injectors and fuel pump) and i have a 3inch AFM. Im not sure what it could be, I dont even know where to start. the only thing i can say is that its not because the car is to rich... checked a volt meter and the tune is cherry. Could it be something with the ECU or does the 89 have some crazy limiter that i dont know about???? has anyone run across this problem or does anyone have any thoughts... im open to try anything, i cant race anyone till i get this fixed... i spin till about 80 and then just hit the limiter... damn 195's and open diff.Jake
