dizzywithsunstroke »
https://forums.nicoclub.com/dizzywithsunstroke-u83573.html
Thu Jun 19, 2008 1:46 pm
ok guys. got my car running about a month ago but i need some help. lately, about every other time i go to drive my car, it will not rev over 3800 rpms, (or so it says on my stock 240 tach, i haven't got a new one yet). i really think it has to do with the maf sensor. i just wanted to check up on the wiring and see if it is correct before i go buy a new maf.
i have pin 1 as blankpin 2 as the air signal- black wirepin 3 as the power ground- yellow wire, red stripepin 4 as the signal ground- white wirepin 5 as the power- white wire
when i sent the harness off to be wired, i didn't have a maf plug so i had to put one on afterwards.
this is how the stephen from swap wiring told me to wire it. it was working fine but now i have run into this problem.
another thing that makes me wonder is the fact that there are 5 wires coming out of the harness but only 4 go to the plug. i dont know what the 5th wire is.the one on the left that has no coating.
any help would be appreciated. thank you.
