evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Feb 18, 2010 9:28 pm
welcome to nico and congrats on the z
we don't have an L6 series engine forum as the L6 was found only in the 70-83 z cars and the 810 and first gen maxima, so the classic Z section is the place for all your L6 needs
just to be clear the L6 is the engine family and the L28ET specifies it as the 2.8 liter fuel injected turbo engine, this was available only fomr 81-83 in the 280zx, in 81 it was available only on automatic equipped cars and used an unique crank mounted trigger, the 82-83 model is far more common and uses the distributor based cas
the turbo 82-83 models that had a manual trans was equipped with a beefy and very desirable T5 trans
the 280 was the only z car sold in the US that was offered with the turbo option, al other generations of z's that had available turbo's were not offered wiht the 2+2 option, oddly it seems the majority of the S130 turbo's were 2+2's (S130 is the chassis designation for the 79-83 280zx)
also all turbo S130's came wiht T tops
the stock turbo is a garret T3 with a unique downpipe flange
the fuel injection is a bosche L jetronic, most issues wiht these cme form the cas in the distributor, the ignitor mounted to the side of the ignition coil, the AFM, or simply wiring issues usually hardened and broken at the injector connectors
oh and the digital dash models tend to have issues wiht the power supply or display unit
