need list of parts to swap sr20 turbo system to ka24de
dezi
Car: 1992 nissan 240sx
i need a list fromstart to finish so if anyone could help me out here i would really appreciate it i wana start collecting parts so i can work on it in the winter.
uncle_louie83
Car: 1993 Nissan 240sx Coupe
mmmm...i think everything should work as long as you get a different turbo manifold...just modify the pipe that goes into the intake a lil bit...other than that...get you some sort of engine management and have at it...and make sure you get the 370's if your gonna go that route also.
lewis
dezi
so basically everything off the sr20
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
You will need: (search about each one, and you will see in exact detail about each item)
turbo manifoldturboOil feed and drain lineswastegate (unless the turbo comes with an internal one)down pipe form turbo to exhaust systemIntercooler and pipingBlow off Valvebetter fuel pumpBigger injectorsFuel management to control the bigger injectorsGauges to keep things in check
hannibal
Car: Red Line to Glenmont
I think he was asking what parts he could use from a SR20DET for his KA-T.
T25/T28 turbomanifold? (you would have to replace the SR exhaust flange with a KA exhuast flange)downpipe? (not sure if the SR manifold on a KA will put the turbine outlet in the same position, you could probably modify it to work at least)side mount IC and piping
I think thats it...
