Need interior LED map light help.
dudestfuplease
Car: 2009 White Altima Coupe 2.5
i installed blue leds into my maplights but i think the bulb housing or whatever the thing is called(the part you stick the bulb into) is loose so whenever i try to turn on the light it doesnt turn on. is there anyway i can fix this?
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
If it doesn't turn on at all I would think you have the led backwards.
That's all the help I can give though, that and check your fuses. But it seems that if that's the only thing not working it wouldn't be a fuse
