1995240sxSE »
https://forums.nicoclub.com/1995240sxse-u36164.html
Sun Jun 03, 2007 4:47 pm
I was just trying to tune mine today and I found many boost leaks. But before I had boost leaks I blew off 3 different intercooler ines at 5 psi! Is your afc wired correctly??????? If it doesnt measure air chances are no!!! double check your wiring!!! Secure your hoses well! booast away. use the top nipple beside the adjuster screw on your bov. and once all is good read my sig and DO IT!!!
your afc doesnt measure psi! A boost gauge reads that afc taps into computer and displays airflow, throttle position rpms, voltage, correction, knock and ummm I use the 4 display and look at rpm, throttle airflow and voltage!
